SKacc's avatar
SKacc
6 years ago
Does 120 ohm pull up with LED indication work for CONF_DONE for 5AGXMB1 FPGA?
As per datasheet, 10K is recommended to pull up for CONF_DONE. Attached the circuit followed in our product.
  • Hi SKacc,
    Intel recommended 10k to pull up for CONF_DONE. 120 ohm can be use, but Intel will not be responsible if it is not working for the device. Hence it is better to follow Intel's guidelines.
    Thank you.
    Aim
    • SKacc's avatar
      SKacc
      Hi Aim
      Is there any other method for FPGA configuration status visual indication?
      Srikanth Kacchu
  • Hi Srikanth Kacchu,
    Usually we used LED to see the status. The LED will turn green after the conf is done. Below is the example by using Cyclone 10:
    Aim
  • Hi,
    I am having an error to insert image in here, hence please look in your private message in forum for the image.
    Aim
    • SKacc's avatar
      SKacc
      Hi Aim
      I couldn't find the image in My Messages. Can you able to send any link?
      Srikanth Kacchu
    • SKacc's avatar
      SKacc
      Hi Aim
      Where can I see your message? If possible, please share the information to my mail [email protected].
      Srikanth Kacchu
