okramer
6 years agoDo I need USB driver on host for Arria 10 GX dev kit (PCIe)?
The PDF that came with my Arria 10 GX development kit says: The development board includes integrated USB-Blaster circuitry for FPGA programming. However, for the host computer and board to communic...
okramer
6 years agoFollowing the instructions in that document, I can make the board visible on PCIe:
$ lspci | grep Altera
a1:00.0 Processing accelerators: Altera Corporation Device 2494 (rev 01)Also, "aocl install $INTELFPGAOCLSDK/board/a10_ref" successfully compiled source and installed. But diagnose gives:
$ aocl diagnose
ICD System Diagnostics
Using the following location for ICD installation:
/etc/OpenCL/vendors
Found 4 icd entry at that location:
/etc/OpenCL/vendors/Altera.icd
/etc/OpenCL/vendors/nvidia.icd
/etc/OpenCL/vendors/Intel_FPGA_SSG_Emulator.icd
/etc/OpenCL/vendors/intel64.icd
the following OpenCL libraries are referenced in the icd files:
libalteracl.so
libnvidia-opencl.so.1
libintelocl_emu.so
/home/okramer/system_studio_2019/opencl_compilers_and_libraries_18.1.0.013/linux/compiler/lib/intel64_lin/libintelocl.so
checking LD_LIBRARY_PATH for registered libraries:
libalteracl.so was registered on the system at /home/okramer/intelFPGA_pro/19.3/hld/host/linux64/lib
libnvidia-opencl.so.1 was registered on the system at /usr/lib/x86_64-linux-gnu
libintelocl_emu.so was registered on the system at /home/okramer/intelFPGA_pro/19.3/hld/host/linux64/lib
/home/okramer/system_studio_2019/opencl_compilers_and_libraries_18.1.0.013/linux/compiler/lib/intel64_lin/libintelocl.so was registered on the system.
Using the following location for fcd installations:
/opt/Intel/OpenCL/Boards
Found 1 fcd entry at that location:
/opt/Intel/OpenCL/Boards/a10_ref.fcd
the following OpenCL libraries are referenced in the fcd files:
/home/okramer/intelFPGA_pro/19.3/hld/board/a10_ref/linux64/lib/libaltera_a10_ref_mmd.so
/home/okramer/intelFPGA_pro/19.3/hld/board/a10_ref/linux64/lib/libaltera_a10_ref_mmd.so was registered on the system.
Number of Platforms = 4
1. Intel(R) FPGA SDK for OpenCL(TM) | Intel(R) Corporation | OpenCL 1.0 Intel(R) FPGA SDK for OpenCL(TM), Version 19.3
2. NVIDIA CUDA | NVIDIA Corporation | OpenCL 1.2 CUDA 10.1.236
3. Intel(R) FPGA Emulation Platform for OpenCL(TM) | Intel(R) Corporation | OpenCL 1.0 Intel(R) FPGA SDK for OpenCL(TM), Version 19.2
4. Intel(R) CPU Runtime for OpenCL(TM) Applications | Intel(R) Corporation | OpenCL 2.1 LINUX
ICD diagnostics PASSED
BSP Diagnostics
Warning:
No devices attached for package:
Vendor: Intel(R) Corporation
Found no active device installed on the host machine.
Please make sure to:
1. Set the environment variable AOCL_BOARD_PACKAGE_ROOT to the correct board package.
2. Install the driver from the selected board package.
3. Properly install the device in the host machine.
4. Configure the device with a supported OpenCL design.
5. Reboot the machine if the PCI Express link failed.
DIAGNOSTIC_FAILED
Call "aocl diagnose <device-names>" to run diagnose for specified devices
Call "aocl diagnose all" to run diagnose for all devicesSpecifically, "Warning: No devices attached for package: /home/okramer/intelFPGA_pro/19.3/hld/board/a10_ref" seems like the problem. But I don't know what to do about that. The same issue persisted in this thread. I checked everything that was mentioned in that thread along with other threads referenced, but no luck. The OP said he finally fixed it by moving the board to a different PCI slot. I guess I have to try that (I have a GPU in another slot). Tried that but still get "no device attached" message.
