okramer
6 years agoDo I need USB driver on host for Arria 10 GX dev kit (PCIe)?
The PDF that came with my Arria 10 GX development kit says: The development board includes integrated USB-Blaster circuitry for FPGA programming. However, for the host computer and board to communic...
Nathan_R_Intel
Contributor
6 years agoHie,
It seems the PCIe link is not up.
Please ensure you are following the steps described in the user guide on configuring the PCIe configuration (Pg 4-6 onwards).
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/ug_a10-fpga-prod-devkit.pdf
After configuring the correct PCIe design, you can check in the "System Info" Tab whether the correct PCIe design configuration is loaded. This should enable the PCIe tab to work. If it still does not work, please try re-start the host PC without power cycling the board. This should resolve your issue.
Do let me know if my suggestions fixes your issue.
Nathan
