Distinguish if a FPGA image was loaded from flash or directly to the FPGA via JTAG
Hi fellows,
is there a way to distinguish, if a FPGA image was loaded from the external flash or it was downloaded via JTAG?
I would like to implement the differentiation in my FPGA logic.
So if the image gets loaded from the flash something different shall be done compared when the image is loaded via JTAG.
Thanks in advance and best Regards,
Joda
You can distinguish them by checking the MSEL status on the board.
Aiman
- FvM
May be possible in remote system upgrade configuration. It has a status register that shows the most recent reboot cause. - NurAiman_M_Intel
Aiman
- Joda
Thank you both!
@FvM indeed the RSU provides such a register to distinguish. However, as far as I looked into it, it seems that it only allows to distinguish between the factory and application image. I have to double check the register, when loading an image including the RSU directly via JTAG to the FPGA.
@NurAiman_M_Intel Thank you, this looks promising.
Joda
- NurAiman_M_Intel
