Joda
3 years agoDistinguish if a FPGA image was loaded from flash or directly to the FPGA via JTAG
Hi fellows,
is there a way to distinguish, if a FPGA image was loaded from the external flash or it was downloaded via JTAG?
I would like to implement the differentiation in my FPGA logic.
So...
- 3 years ago
You can distinguish them by checking the MSEL status on the board.
Aiman
Joda
3 years agoThank you both!
@FvM indeed the RSU provides such a register to distinguish. However, as far as I looked into it, it seems that it only allows to distinguish between the factory and application image. I have to double check the register, when loading an image including the RSU directly via JTAG to the FPGA.
@NurAiman_M_Intel Thank you, this looks promising.
Joda
