msc
9 months agoDifferential Signal Transmitter on Agilex 5 FPGA Modular Dev Kit
We will use the SOM Module of the Agilex 5 FPGA E-Series 065B Modular Development Kit (MK-A5E065BB32AES1) for a new project with our own designed carrier board. For this design we need multiple diff...
AqidAyman_Altera
8 months agoHi,
It is expected that Quartus don't allow you to use 1.2V bank supply with TDS transmitter pins. Based on the datasheet, transmitter pin can only use 1.3V TDS.
And it is also expected to be compatible with LVDS Receiver (for certain data rates, you can DC coupled to interface the TDS TX with LVDS RX).
For more information, you may refer to this Application Note from below link:
AN 555: https://docs.altera.com/r/docs/776775/current/an-555-true-differential-signaling-termination-and-biasing-for-agilextm-7-m-series-agilextm-5-and-agilextm-3-fpgas/minimum-vod-lvds-transmitter-interfaces-with-1.3-v-tds-receiver
Aqid
