MHamz1New Contributor6 years agoDifferent behavior on different CPLDs I am using the MAX V series CPLDs, I am experiencing different behavior of same RTL on the different models of MAX V CPLDs, My RTL works fine on "5M570ZF256C5" but when I port the same onto "5M570ZT...Show More
sstrellSuper Contributor6 years agoDo you have simulation or Signal Tap data to show what exactly you are seeing? Or it could be a timing issue. Can you post your .sdc file?#iwork4intel
Recent DiscussionsDE10-Lite unable to flash?Device stopped receiving config data: Internal error (0x0000, 0x00000000, 0x1800).Stratix 10 GX SI Board - issue with the Board Test System (BTS)About PCIe Daughter Cards for Agilex™ 3 FPGA and SoC C‑Series Development KitAvailable replacement for the discontinued P/N: MK-A5E065BB32AES1 ?
