MHamz1
7 years agoDifferent behavior on different CPLDs
I am using the MAX V series CPLDs, I am experiencing different behavior of same RTL on the different models of MAX V CPLDs, My RTL works fine on "5M570ZF256C5" but when I port the same onto "5M570ZT...
MHamz1
7 years agoThank you for your reply , Yes the clock speed is same in both devices, I am able to solve the problem by an alternate way i.e by replacing some SIGNALS with VARIABLES however i am still unclear that what is the problem in using SIGNALS,
I will share the sdc file shortly with you
- MHamz17 years ago
Timing Analyzer Summary
Type : Setup 'CLK'
Slack : -26.114
TNS : -5667.650
Type : Hold 'CLK'
Slack : 1.728
TNS : 0.000
Type : Minimum Pulse Width 'CLK'
Slack : -2.289
TNS : -2.289
