MHamz1
7 years agoDifferent behavior on different CPLDs
I am using the MAX V series CPLDs, I am experiencing different behavior of same RTL on the different models of MAX V CPLDs, My RTL works fine on "5M570ZF256C5" but when I port the same onto "5M570ZT...
SreekumarR_G_Intel
7 years agoI assume clock rate is same between old and new device.As Steven said you can load the sdc file and check the timing slack in the timing analyzer.
Could you post the timing report as well ?
Thank you ,
Sree
