14 years agoDev board with Ethernet & a few IO?
In order to allow a new client to prove a concept I'm looking for a basic/ cheap Altera FPGA eval board with ethernet and a few digital IO lines (although the IO lines aren't critical if there's an H...
14 years ago --- Quote Start --- The BeMicro-SDK $79 has an ethernet interface and GPIO via an expansion header. The board uses low-power DDR, which is not supported directly by Altera's IP core, you have to use a 3rd party block. I have this board, but have had no need to use the ethernet or DDR. Cheers, Dave --- Quote End --- Thansk Dave, I don't need to implement an ethernet stack so this looks ideal. I owe you a pint! Nial.
