14 years agoDev board with Ethernet & a few IO?
In order to allow a new client to prove a concept I'm looking for a basic/ cheap Altera FPGA eval board with ethernet and a few digital IO lines (although the IO lines aren't critical if there's an HSMC connector).
I thought the CycloneIII started board would be ideal but hadn't realised this has no e'net connectivity. I can't find a basic/ cheap board through the altera site, does anyone have any suggestions? Thanks for any pointers, Nial.6 Replies
how cheap is cheap?
The BeMicro-SDK $79 has an ethernet interface and GPIO via an expansion header. The board uses low-power DDR, which is not supported directly by Altera's IP core, you have to use a 3rd party block. I have this board, but have had no need to use the ethernet or DDR.
The Cyclone IV GX Transceiver Starter kit $395 has ethernet and PCIe, but no HSMC it http://www.altera.com/products/devkits/altera/kit-cyclone-iv-starter.html if you did not need much I/O, the LCD header could be removed. The DE2-115 and NEEK from Terasic probably have what you need: http://www.terasic.com.tw/cgi-bin/page/archive.pl?language=english&categoryno=13&list=simple Cheers, Dave - Altera_Forum
--- Quote Start --- The BeMicro-SDK $79 has an ethernet interface and GPIO via an expansion header. The board uses low-power DDR, which is not supported directly by Altera's IP core, you have to use a 3rd party block. I have this board, but have had no need to use the ethernet or DDR. Cheers, Dave --- Quote End --- Thansk Dave, I don't need to implement an ethernet stack so this looks ideal. I owe you a pint! Nial. - Altera_Forum
--- Quote Start --- I don't need to implement an ethernet stack so this looks ideal. --- Quote End --- Download the USB-Blaster SOPC/Qsys tutorial. It has the BeMicro-SDK pinouts and an example design you can use. http://www.alterawiki.com/wiki/using_the_usb-blaster_as_an_sopc/qsys_avalon-mm_master_tutorial --- Quote Start --- I owe you a pint! --- Quote End --- I'm at the Embedded Systems Conference in San Jose this week. I'd be more than happy to collect that beer if you are nearby :) Cheers, Dave - Altera_Forum
--- Quote Start --- Download the USB-Blaster SOPC/Qsys tutorial. It has the BeMicro-SDK pinouts and an example design you can use. http://www.alterawiki.com/wiki/using_the_usb-blaster_as_an_sopc/qsys_avalon-mm_master_tutorial --- Quote End --- I'll have a look if this proceeds, thanks. --- Quote Start --- I'm at the Embedded Systems Conference in San Jose this week. I'd be more than happy to collect that beer if you are nearby :) Cheers, Dave --- Quote End --- Unfortunately I'm ~6K miles away in Edinburgh. I'll buy you that pint next time I'm over there, or you're over here! Nial. - Altera_Forum
Hi Nial,
--- Quote Start --- Unfortunately I'm ~6K miles away in Edinburgh. I'll buy you that pint next time I'm over there, or you're over here! --- Quote End --- I'll add you to my "world tour of beer's owed" collection trip. Cheers, Dave
