14 years agodesign of an RFID system reconfigurable on FPGA
Hi, all I currently have a project that asked me to develop an architecture of an RFID system including the various aspects encoding / decoding, modulation / demodulation,anti-collision, securi...
14 years ago --- Quote Start --- sir i want to implement rfid through fpga that will sort out the parcels of particular countries the rfid tags were pasted on the parcels. can you please help me in that project ?? --- Quote End --- I have no experience with RFIDs. However, I will provide advice on your project. First, get the part numbers of the RFID tags and reader. Second, determine whether you need to use an FPGA. I doubt that you will require an FPGA. RFID tags are supposed to be cheap, and although the readers will be more expensive than the tags, the readers also need to be cheap. A microcontroller would likely be more appropriate for a commercial application such as parcel sorting. However, if you do want to implement a system using FPGAs, the users of this forum will help provide direction. Cheers, Dave
