13 years agoDE5-NET Not configuring
Hi all,
I tried to program the Stratix V FPGA on the DE5-NET board through JTAG using the UBS Blaster cable. Each time, the programmer goes up to somewhere between 95% - 98% and fail. The error i get is "Error 209014 CONF_DONE pin failed to go high in device 1". I have set the MSEL[4:0] in 0 position. I also noted that in the LED array near the USB blaster port on the board, only the JTAG Tx LED blinks while the programming is going on. The Rx LED never lights up. Any ideas on why this is happening and a way work around this is much appreciated.. - IsuruNo RepliesBe the first to reply
