12 years agoDE4 Simple Server Socket example
Hi, I have an Altera DE4 Development and Education Board. I’m using Quartus II 11.0. I’m trying to run “Simple Socket Server (RGMII)” example. This is the ‘Nios II Console’ output: =====...
12 years agoForgive me if these are stupid questions, but I don't know your expertise level with network and embedded systems:
- are your sure the DE4 board is actually initializing with valid mac/ip addresses, as I said above? - did you try a simple ping before testing the telnet connection? - did you check your pc network configuration? did you configure the same subnet?
