17 years agoDE2 Flash READ/Write
I am trying to write my output results on to flash( s29al032d mode 3) and then I want to read that results again in another code. I have written code which controls flash using it's CE,OE,WR,RESET...
15 years agoAre you giving it all the right parameters for the api call? If you're using the eclipse environment you can use control+spacebar to get a hint of the parameters required, or use F3 with the function call selected to see it's prototype.
