17 years agoDE2 Flash READ/Write
I am trying to write my output results on to flash( s29al032d mode 3) and then I want to read that results again in another code. I have written code which controls flash using it's CE,OE,WR,RESET...
15 years agoI have interfaced manually the flash memory so, I am sorry, i don't know why you have always 0 (alt_flash_open_dev is an api for NIOS that's right?). Only one suggestion if you haven't already done. Try to write in flash... after check that with control panel, it is very easy to use.
I hope to be more useful next time. Regards, AV
