17 years agoDE2 Ethernet Primitive Solution
With the DE2 board, the Ethernet controller does not seem to work in Quartus II 8.0 or 8.1. There are several problems with the DE2_NET demonstration; it was built pre-7.1, the software driver does n...
16 years ago --- Quote Start --- Thanks for your advice. I have added the codes , Tmp = ior(0xF5); Tmp = ior(0xF4); into ReceivePacket function. It works! I can receive continuous data from pc. It seems to reset the DM9000A memory data address to 0x0c00. In the read memory operation, when the bit 7 of IMR is set, the memory address increment will wrap to location 0x0c00. --- Quote End --- to Li.Huiliang, you did it successfully,while i'll do the same thing with you with a DE2 ,but i don't know how to start it ,can you give me the code that you just succeed.please send to [email protected] ,i'll be very thankful!
