17 years agoDE2 Ethernet Primitive Solution
With the DE2 board, the Ethernet controller does not seem to work in Quartus II 8.0 or 8.1. There are several problems with the DE2_NET demonstration; it was built pre-7.1, the software driver does n...
16 years agoThanks for your advice.
I have added the codes , Tmp = ior(0xF5); Tmp = ior(0xF4); into ReceivePacket function. It works! I can receive continuous data from pc. It seems to reset the DM9000A memory data address to 0x0c00. In the read memory operation, when the bit 7 of IMR is set, the memory address increment will wrap to location 0x0c00.
