17 years agoDE2 Ethernet Primitive Solution
With the DE2 board, the Ethernet controller does not seem to work in Quartus II 8.0 or 8.1. There are several problems with the DE2_NET demonstration; it was built pre-7.1, the software driver does n...
16 years ago:confused:
--- Quote Start --- I am trying to use ur code for DM9000A, but without LCD.h and test.h. but the driver could not initialize the DM9000A and prompts "DM9000A failed" what may be the problem? can u help --- Quote End --- Are you using the DE2_NET example? It shipped with the board on a disk; without it, the code I wrote is pretty useless. Also, an e-mail address will help. I'm usually against doing other people's work, but I can hand over what I developed if everything is on a university chain. This is pretty involved, I also need to know a bit about which HW modules you are using. The problem I ran into was I would receive one packet and never get another.
