17 years agoDE2 Ethernet Primitive Solution
With the DE2 board, the Ethernet controller does not seem to work in Quartus II 8.0 or 8.1. There are several problems with the DE2_NET demonstration; it was built pre-7.1, the software driver does n...
17 years agoI agree fully; the central reason I posted the code was it worked. With Quartus 8 and 8.1 web, I could not get packet reception, even at a very slow rate, without the system crashing.
Re-initializing is sloppy and is probably the equivalent of killing a fly with an RPG. I will post a later revision, probably toward the end of this month, or early April, which will contain the the proper sequence for packet reception. For some reason, I could not get the loop-back functionality to work for packet reception; I'll have to play around with it. The primary reasoning for this thread is to get someone off the ground who is having the same problem. My current thought is the drive is not entirely functional for reception; the interrupt mask may not be cleared or the memory does not flush, indicative of an issue with the DE2_NET demo. Thank you for taking the time to go through this; if you find a solution before me, I would love to see it. I'm really only interested in the primitives. Thank You, Adam F.
