14 years agoDE2-115/tPad and RS-232
Hello, I've been fiddling a bit with this lately, interfacing with the UART chip on this board, and running into some strange problems. As far as I can see there are 4 ports/pins available...
14 years agoAn RS232 UART has the 4 signals that you mention. When such a UART is not used together with a Modem, only the TXD and RXD are used. For example to send or receive something from your Garmin.
To test a UART you can simple hook it up to a serial port of your PC and use a program like HyperTerminal or other to see if the link works. The easiest to get your UART working is to make a project with SOPC and a NIOS processor. SOPC (or QSYS) do have modules for UARTs.
