12 years agoDe2-115 windows application to control Cyclone chip
Hi, I bought Altera board (development) DE2-115 In the example CD - there is a very nice PC application with UI - when pressing buttons-> altera board light leds, show LCD when you write in PC e...
12 years ago --- Quote Start --- Here is my very basic knowledge at this points about Jtag, --- Quote End --- JTAG is simply a synchronous serial interface, i.e., it has a clock, data in, data out, and a mode/select bit. Its no more difficult to understand than SPI. However, unlike SPI, there is a standard 'state machine' called the TAP (test access port), which includes instruction and data registers, which you load and read to perform JTAG transactions. Altera has layered their Virtual JTAG Interface on top of JTAG. The Virtual JTAG interface is implemented in the fabric of the FPGA. Altera define a couple of JTAG instructions for manipulating their Virtual Instruction register and Virtual Data register. This is all explained in this document: http://www.ovro.caltech.edu/~dwh/correlator/pdf/vjtag.pdf If this seems overly complicated, you could always just connect a UART to pins on the DE2-115 and write a serial port application. FTDI make several cables that I use; http://www.digikey.com/product-detail/en/c232hm-ddhsl-0/768-1106-nd/2714139 http://www.digikey.com/product-detail/en/c232hd-ddhsp-0/768-1011-nd/2767783 Cheers, Dave
