12 years agoDe2-115 windows application to control Cyclone chip
Hi, I bought Altera board (development) DE2-115 In the example CD - there is a very nice PC application with UI - when pressing buttons-> altera board light leds, show LCD when you write in PC e...
12 years agoHi all,
Thanks to Dave I have made a big progress with this project I can now see JTAG is working and send commands - working!!! I just did adjustment to DE2-115 board (which altera chip is CYCLONE IV E) since the main chip and pins are totally different. Also major changes with components on board (e.g. VGA is now only 8 bits, instead of 10 bits on older board, memory sizes are bigger, and Ethernet controller is different, and many more changes) - almost done with changes Just wonder if I enter CYGWIN and do all process after command: tcl> jtag_vir 0x1234 can't send the command: tcl> jtag_vir 0x1111 like Jtag is closed and need all process from beginning ... Also I could not implement all commands to TCL together, because when entering $ quartus_stp -s commands afterwards are not seen attached example file that doesn't work Thanks, Roee
