12 years agoDe2-115 windows application to control Cyclone chip
Hi, I bought Altera board (development) DE2-115 In the example CD - there is a very nice PC application with UI - when pressing buttons-> altera board light leds, show LCD when you write in PC e...
12 years agoIs it really possible to damage this boards with wrong configuration?
If you have signals contention, and the board designer was experienced so you shouldn't worry about board damage :) This is like saying - if you use your PC computer with wrong SW you can burn your PC, I hope this is not possible in this board I have TCL file of the DE2-115, I have used your script, but change the "proc get_pin_constraints {arg} {" to my board, I guess this is not enough - because the pins name might be different in the VHDL code you used - is this correct? I have attached the updated TCL for DE2-115 Thanks, Roee
