12 years agoDe2-115 windows application to control Cyclone chip
Hi, I bought Altera board (development) DE2-115 In the example CD - there is a very nice PC application with UI - when pressing buttons-> altera board light leds, show LCD when you write in PC e...
12 years ago --- Quote Start --- I am using DE2-115 board, so the cyclone II doesn't match --- Quote End --- I know, that is why I warned you NOT to use it directly. --- Quote Start --- I have changed the Device to my device - should I make any more changes? (I guess the TCL that configure pins is not the same) correct? --- Quote End --- Of course, you have to change the pin assignments. That is clearly stated in the readme.txt. Did you not read it? --- Quote Start --- Also seen you configure many things - I guess I don't need so many correct? --- Quote End --- This question is not clear. --- Quote Start --- if just changing Altera to mine I get garbage on LCD --- Quote End --- If you downloaded the design without changing the pin assignments, you may also have damaged your board. Cheers, Dave
