12 years agoDe2-115 windows application to control Cyclone chip
Hi, I bought Altera board (development) DE2-115 In the example CD - there is a very nice PC application with UI - when pressing buttons-> altera board light leds, show LCD when you write in PC e...
12 years agoThanks!
I am using DE2-115 board, so the cyclone II doesn't match I have changed the Device to my device - should I make any more changes? (I guess the TCL that configure pins is not the same) correct? So I will have to use my own TCL for pin configuration. Also seen you configure many things - I guess I don't need so many correct? if just changing Altera to mine I get garbage on LCD Thanks, Roee
