12 years agoDe2-115 windows application to control Cyclone chip
Hi, I bought Altera board (development) DE2-115 In the example CD - there is a very nice PC application with UI - when pressing buttons-> altera board light leds, show LCD when you write in PC e...
12 years ago --- Quote Start --- Something I misunderstand, If I am using JTAG debugger (in Programmer), I can move bits to JTAG and make CLOCKS and see TDO as I expect, But when I see TDO=1 => I don't see my green led on board lighting? why is that am I missing something? --- Quote End --- It does not work because you have not read any of the documentation and understood how the JTAG component works. The TDO from the SLD_Virtual_JTAG component is *NOT* the same as the external pin. There is multiplexing logic in the SLD_Virtual_JTAG component. You need to issue JTAG commands to select your component first. The vjtag.pdf document contains example Tcl code and SignalTap II logic analyzer traces. Add a SignalTap II instance to your design and you will see that TDO will not change until you issue the correct commands. Cheers, Dave
