15 years agoDE2-115 Web Server Example
Hi, I'm new to Quartus and Nios, and I've been trying to get the DE2-115 web server example (RGMII-ENET0) running with no luck. I followed the instructions in the user manual trying the bat fi...
15 years agoDear Daixiwen
I check many times , the folder and project is same of directory. but , I found , the example of SOPC Builder already have system id for include , so I try again. 1. Open d:\DE2_115_Web_Server\DE2_115_WEB_SERVER_RGMII_ENE T0 DE2_WEB_SERVER.qpf file in Quartus 10.1 2. SOPC Builder(no change anything to example) 3. Click Generate(successful) 4. Compile .qpf project in Quartus(but don't have download to de2-115) 5. Start up Nios 10.1 → File > New > Nios II Application and BSP Template (Finsh reference of step No.11 ~ No.15) 6. Open up Nios 10.1 Command Shell and enter code but ... the message again tell me ----------------------------------------------------------- Timestamp value was not verified : value was not specified The software you are downloading may not run on the system which is crrrently configured into the device . Please download the correct SOF or recompile . Leaving target processor paused ----------------------------------------------------------- I think...maybe , I need enter SOPC Builder and delet system id of original , and add new system id (system id parameters not change) maybe need this make... I will try again : ) p.s It is to strange , before in the SOPC Builder. If I add a new system id (I don't delet or change the origin system id). and Builder → Generate → Compile , but in the Nios 10.1 Command Shell haven't any questione , only questione is due to can't ... In NiosII download software to De2-115...
