15 years agoDE2-115 Web Server Example
Hi, I'm new to Quartus and Nios, and I've been trying to get the DE2-115 web server example (RGMII-ENET0) running with no luck. I followed the instructions in the user manual trying the bat fi...
15 years agoHi Windex
I try your support a methods[/U] [/U] I open the Nios 10.1 Command Shell and enter the code but , when I enter the code : nios2-flash-programmer.exe...--erase-all the message tell me ---------------------------------------------------------------------------- There are two or more JTAG cables available but you have not chosen which one to use. please use the configuration dialog to pick one, or specify a value for the --cable parameter on the command line. ---------------------------------------------------------------------------- I try a long time , but still appear this message ...
