9 years agoDE2-115 tPad LCD-TFT 800x600 Display timing
Hello, I'm fiddling with this development kit, and struggle with understanding the Terasic spec from the tPad User Manual. https://www.cl.cam.ac.uk/teaching/1314/ecad+arch/labs/files/tpad_use...
9 years agoHi, just at first eye view, I don't see front and back porch timing nor I see sync timing, these are to be respected otherwise LCD panel can be damaged or display in worst mode.
After that you need also stream out pixel data from memory, if some color translation exist map also color space before to drive display digital lines. Regards
