12 years agoDE2-115 Programming: No hardware detected
Hello, i have 3 Developement boards. With the first 2 i don't have problems to program. Since i adoped the project from a collaborator witch announced, i don't know if he did something i don't kno...
12 years agoHi David,
thank you for your response. Fortunately i could now program the new board, unfortunately i don't know why... I asume, that i made something wrong while programming but i didn't recognize any differences. So far so good. As I said, my predecessor implemented the hole configuration. I now have a manual how to: generate qsys, revert (from svw) compile VHDL, generate bsp, revert, compile program since there are some changes from normal generations. Anyway, after converting i get a .jic file witch i can program to the board. The switch can be set on Run if i do this. I know that this isn't the straigt way you describe in the manuals. But i am not an microelectronic specialist only concerning on the firmware. (If i get no problems) We are searching a specialist in FPGA but until now we were not successful. Thank you anyway, Thomas
