12 years agoDE2-115 Programming: No hardware detected
Hello, i have 3 Developement boards. With the first 2 i don't have problems to program. Since i adoped the project from a collaborator witch announced, i don't know if he did something i don't kno...
12 years agoHi there,
Could you first check if Altera USB-Blaster is detected properly ? You can check this in Quartus Programmer or the device manager from your PC. I'm also a bit confused about the file format and the type of programming method you mentioned, despite all the settings are the same on these 3 DE2-115 boards. Is the RUN/PROG switched to RUN or PROG to program .jic, .sof, or .pof ? David from Terasic
