14 years agoDE2-115 Multiplexed SRAM
Using TerASIC SRAM component (tested and verified) and wanted to add a second Avalon MM slave. Created a second component with a MM master and a signal to control the mux selection. SRAM component is attached to NIOS CPU with address_master and data_master and attached to my component via SOPC builder. Mux control seems to work. When I select CPU, i can read and write SRAM from the CPU. However, when I try to access via my component, I get all 0xFF.
Basic design of my components memory master is this (all I want to do is read the SRAM. It is inside an always loop based on system clock: state 0: chip_select_n <= 0; write_n <= 1; address <= {12'b0,address_to_read); read_n <= 0; lbe_n <= 0; hbe_n <= 0; go to state 1 state 1: go to state 2 state 2: my_data <= readdata; chip_select_n <= 01; write_n <= 1; address <= 32'bz read_n <= 1; lbe_n <= 1; hbe_n <= 1; Any thoughts on why I shouldn't be able to read on the non-CPU side of the MUX? Is my configuration valid given the Avalon MM paradigm. Thanks, in advance, MENo RepliesBe the first to reply
