ZKhan1's avatar
ZKhan1
7 years ago
DE2-115 Media Example
Hi all ,
I have been trying to run DE2-115 Media Computer example with no success. I tried to compile its Nios app in eclipse but i always get "Make elf error 1" . I have tried modifying i.e connecting a On-chip Ram in its SOC design with multiple sizes from 8k , 16k and 20K , but after successful HW compilation i still get " elf error1 " .
I have even tried modifying SOC design with no GPIO , no UART and no USB , no success again ????
Any ideas why software compilation is not working ?
Regards , Ahmed
  • ZKhan1's avatar
    ZKhan1
    tried it again with 32bit-by-140K, no success, see screen shot attached
  • ZKhan1's avatar
    ZKhan1
    is it ok to refresh the project and re-generate bsp again in nios ide , after a new Quartus project compilation or do i have to create new nios project altogether ???
  • Ahmed_H_Intel1's avatar
    Ahmed_H_Intel1
    I prefer to re-create a new project based on the new sopcinfo and copy the same code to it.
    make sure that you download the new .sof file to the board
    once you build the project please check the console if there is any error.
  • ZKhan1's avatar
    ZKhan1
    created a brand new nios-ii project as hello world which generated bsps , deleted the hello_world.c and included all the example .c files for test_computer , still the same results , NO SUCCESS
    Ahmed_H_Intel1
    Do you see this error even with Hello World example (before adding your code)?
    I've tested your files and working fine until printing "Hello from Nios II"
    Can you try this and see? If there is no error then we should run through the code and see. Maybe something went wrong.
    else you can try the following (might help):
    Right click the BSP project ... NIOS II... Edit BSP... check "Enable small C library"
    Right click the project....properties....NIOS II application properties .... choose Debug Level "Level 2" .....Optimization Level "Level 2" .
    Regards.
  • ZKhan1's avatar
    ZKhan1
    Yes simple "Hello World" works OK , see source files for the media example attached .
  • ZKhan1's avatar
    ZKhan1
    i dont see any option to attach files ???
  • ZKhan1's avatar
    ZKhan1
    // test SRAM
    * SRAM_ptr = SRAM_write;
    SRAM_read = * SRAM_ptr;
    if (SRAM_read != SRAM_write)
    memory_error = 1;
    SRAM_ptr += 1;
    SRAM_write = ~SRAM_write;
    if ( eight_sec > 80 )
    eight_sec = 0; // restart the 8-second delay counter
    if ( display_toggle == 0 )
    display_toggle = 1;
    display_buffer[0] = 0xbA55Ed; // code for the word PASSEd
    display_buffer[1] = 0x0;
    display_buffer[2] = 0x0;
    else
    display_toggle = 0;
    display_buffer[0] = 0xdE20115; // code for the word dE2 115
    display_buffer[0] = 0xe7787; // code for the word Error
    while ( 1 )
    Update_HEX_display ( display_buffer[1] );
    return 0;
    * Updates the value displayed on the hex display. The value is taken from the
    * buffer.
    void Update_HEX_display( int buffer )
    volatile int * HEX3_HEX0_ptr = (int *) HEX3_HEX0_BASE;
    volatile int * HEX7_HEX4_ptr = (int *) HEX7_HEX4_BASE;
    int shift_buffer, nibble;
    char code;
    int i;
    shift_buffer = buffer;
    for ( i = 0; i < 8; ++i )
    nibble = shift_buffer & 0x0000000F; // character is in rightmost nibble
    code = seven_seg_decode_table[nibble];
    hex_segments[i] = code;
    shift_buffer = shift_buffer >> 4;
    *(HEX3_HEX0_ptr) = *(int *) hex_segments; // drive the hex displays
    *(HEX7_HEX4_ptr) = *(int *) (hex_segments+4); // drive the hex displays
    return;
    * Updates the value displayed on the red LEDs. The value is taken from the
    * slider switches.
    void Update_red_LED( void )
    volatile int * slider_switch_ptr = (int *) SW_BASE;
    volatile int * red_LED_ptr = (int *) RED_LED_BASE;
    int sw_values;
    sw_values = *(slider_switch_ptr); // Read the SW slider switch values
    if(LED_toggle == 0)
    *(red_LED_ptr) = sw_values; // Light up the red LEDs
    else
    *(red_LED_ptr) = ~sw_values;
    return;
    * Reads characteres received from either JTAG or serial port UARTs, and echo
    * character to both ports.
    void Update_UARTs( void )
    volatile int * JTAG_UART_ptr = (int *) JTAG_UART_BASE;
    volatile int * UART_ptr = (int *) SERIAL_PORT_BASE;
    int JTAG_data_register, JTAG_control_register;
    char JTAG_char;
    int UART_data_register, UART_control_register;
    char UART_char;
    // check for char from JTAG, echo to both JTAG and serial port UARTs
    JTAG_data_register = *(JTAG_UART_ptr); // bit 15 is RVALID, bits 7-0 is char data
    if ( (JTAG_data_register & 0x8000) ) // have valid data to read?
    JTAG_char = (char) (JTAG_data_register & 0xFF); // extract the character
    JTAG_control_register = *(JTAG_UART_ptr + 1); // upper halfword is WSPACE
    if ( (JTAG_control_register & 0xFFFF0000) != 0) // okay to echo char to JTAG?
    *(JTAG_UART_ptr) = JTAG_char; // echo the character
    UART_control_register = *(UART_ptr + 1); // upper halfword is WSPACE
    if ( (UART_control_register & 0xFFFF0000) != 0) // okay to echo char to serial port?
    *(UART_ptr) = JTAG_char; // echo the character
    // check for char from serial port UART, echo to both serial port and JTAG UARTs
    UART_data_register = *(UART_ptr); // bit 15 is RVALID, bits 7-0 is char data
    if ( (UART_data_register & 0x8000) ) // have valid data to read?
    UART_char = (char) (UART_data_register & 0xFF); // extract the character
    *(UART_ptr) = UART_char; // echo the character
    if ( (JTAG_control_register & 0xFFFF0000) != 0) // okay to echo char to serial port?
    *(JTAG_UART_ptr) = UART_char; // echo the character
    return;
    * This code tests the GPIO JP5 expansion port. The code requires one
    * even-numbered data pin(e.g. D2) to be connected with one odd-numbered
    * pin in the port(e.g. D3), which would typically be done using a wire
    * or a pin connector.
    * If the two pins work properly, the code will toggle the red LEDs.
    * The 32 data pins' (D0 to D31) distribution on the 40-pin expansion port
    * is shown at line 51
    void Test_expansion_ports( void )
    volatile int * JP5_EXPANSION_ptr = (int *) EXPANSION_JP5_BASE;
    // set all pins to be outputs and restore 1 to all pins
    *(JP5_EXPANSION_ptr+1) = 0xffffffff;
    *(JP5_EXPANSION_ptr) = 0xffffffff;
    // set the even-numbered pins to be output pins and write 0 to all output pins
    *(JP5_EXPANSION_ptr+1) = 0x55555555;
    *(JP5_EXPANSION_ptr) = 0x0;
    //read the input pins value
    volatile int odd_in = *(JP5_EXPANSION_ptr);
    //if one input pin connected to one output pin, its value would be drawn to 0.
    int odd_correct = (odd_in != 0xaaaaaaaa) ? 1 : 0;
  • ZKhan1's avatar
    ZKhan1
    Hi Embedded_guy , did you looked at the files in folder "source_files" ?
