11 years agoDE2-115 complete beginners question
Hi I am completely new to FPGAs but I am lucky enough to have been given a DE2-115 I know its a big learning curve but being retired I have plenty of time , but I cant even get started to try...
11 years ago --- Quote Start --- They tell me that my board ( from the serial number ) uses the NXP USB but that this will not work with windows 7 only XP They also said that the Cypress USB only works on windows 7 in 32 bit not 64 bit --- Quote End --- I think you can ignore the advice about functionality under Windows for the moment. The board has a USB device attached to the FPGA that you can use for communication with your design. I've never bothered to use it. The board also has an on-board USB-Blaster, and that does work under Windows just fine. If Terasic has changed the USB controller, then they've likely changed the pin assignments on the board, but probably only in a few places. You'll want to make sure you download the schematic for the board revision you own, and determine the pin assignments from that. Do *not* simply use an example design you find on the web! (Including any from Terasic, without first reviewing it!) Cheers. Dave
