14 years agoDE2-115 audio example
Hi , I tried to run the DE2-115 audio example of running and recording audio via audio CODEC chip , by running the batch file. It downloads both the sof and elf but i dont see any messag...
Tim10
7 years agoI had the same problem.
I solved it like this:
- Opened the QPF in Intel/Quartus Prime.
- Attempted to auto upgrade the IP. It failed, but it advised me to manually do the upgrade in Platform Designer. That worked.
- Compiled it.
- Downloaded it.
There is also a bug in the batch file. You need to replace the double backslashes \\ with single backslashes \ and you might need to change bin to bin64:
@ REM ######################################
@ REM # Variable to ignore <CR> in DOS
@ REM # line endings
@ set SHELLOPTS=igncr
@ REM # Variable to ignore mixed paths
@ REM # i.e. G:/$SOPC_KIT_NIOS2/bin
@ set CYGWIN=nodosfilewarning
@%QUARTUS_ROOTDIR%\bin64\quartus_pgm.exe -m jtag -c 1 -o "p;DE2_115_Audio.sof"
@ set SOPC_BUILDER_PATH=%SOPC_KIT_NIOS2%+%SOPC_BUILDER_PATH%
@ "%QUARTUS_ROOTDIR%\bin64\cygwin\bin\bash.exe" --rcfile ".\DE2_115_Audio_bashrc"
pause
