13 years ago
DE2-115 : position of data pin of FLASH and SDRAM
I have a DE2-115 and I try to understand how memories are interfaced. In the "External Memory Interface in Cyclone IV Devices" book I read :
Cyclone IV devices use data (DQ), data strobe (DQS), clock, command, and address pins to interface with external memory.
But I noticed that some of the data pin of the FLASH and SDRAM are connected to simple I/O of the FPGA (DQ4, DQ10, ...). So I wonder if this is a problem that I use standard I/O for the data pin in the design of my circuit board.
The picture below show an example of data pin connected to standard I/O
Thank you in advance for your explanations
Bel'
https://www.alteraforum.com/forum/attachment.php?attachmentid=7491
