9 years ago
DE10-Standard My_First_HPS Error
Hi, I have just started the DE10-Standard kit and run-thru the tutorials included in the package. I was stucked in the My_First_HPS section and got the error below:
"make: *** no rule to make target '/intelfpga/16.1/embedded/ip/altera/hps/altera_hps/hwlib/include/', needed by '-ic'. stop."
https://alteraforum.com/forum/attachment.php?attachmentid=13930&stc=1
Below is my makefile:
target=my_first_hps
alt_device_family?=soc_cv_av
soceds_root?=$(soceds_dest_root)
hwlibs_root=$(soceds_root)/ip/altera/hps/altera_hps/hwlib
cross_compile=arm-linux-gnueabihf-
cflags=-g-wall -d$(alt_device_family)
-i$(hwlibs_root)/include/$(alt_devive_family)
-i$(hwlibs_root)/include/ldflags= -g-wall
cc=$(cross_compile)gcc
arch=arm
build: $(target)
$(target):main.o
$(cc)$(ldflags) $^-o$@
%.o:%.c
$(cc)$(cflags)-c[I] $(CC)$(CFLAGS)-c$<-o$@[/I]lt;-o$@
.phony:clean
clean:
rm-f $(target)*.a*.o*~
Below is my folder structure:
C:\intelFPGA\16.1\embedded
C:\intelFPGA\16.1\embedded\Embedded_Command_Shell.bat
C:\intelFPGA\16.1\embedded\Embedded_Command_Shell.sh
C:\intelFPGA\16.1\embedded\drivers
C:\intelFPGA\16.1\embedded\ds-5
C:\intelFPGA\16.1\embedded\ds-5_installer
C:\intelFPGA\16.1\embedded\embeddedsw
C:\intelFPGA\16.1\embedded\examples
C:\intelFPGA\16.1\embedded\host_tools
C:\intelFPGA\16.1\embedded\ip
C:\intelFPGA\16.1\embedded\my_first_hps
C:\intelFPGA\16.1\embedded\my_first_hps\main.c
C:\intelFPGA\16.1\embedded\my_first_hps\makefile
Rgds,
Joven
    This is my makefile for a "hello world" example coming with the de10 nano board.
    TARGET = my_first_hps
    ALT_DEVICE_FAMILY ?= soc_cv_av
    HWLIBS_ROOT = $(SOCEDS_DEST_ROOT)/ip/altera/hps/altera_hps/hwlib
    CFLAGS = -g -Wall -Werror -I$(HWLIBS_ROOT)/include -I$(HWLIBS_ROOT)/include/$(ALT_DEVICE_FAMILY) -D$(ALT_DEVICE_FAMILY)
    LDFLAGS = -g -Wall -Werror
    CROSS_COMPILE = arm-linux-gnueabihf-
    CC = $(CROSS_COMPILE)gcc
    LD = $(CROSS_COMPILE)gcc
    ARCH = arm
    .PHONY: build
    build: $(TARGET)
    $(TARGET): main.o
    	$(LD) $(LDFLAGS)   $^ -o $@
    %.o : %.c
    	$(CC) $(CFLAGS) -c $< -o $@
    .PHONY: clean
    clean:
    	rm -f $(TARGET) *.a *.o *~
    Not sure what is the problem with yours but I would add:
    .PHONY: build
    and execute make build
    Hi nhasbun,Thanks a lot, it works. Now my next issue is it did not show the "inet addr". i tried few suggestions (eth0 down/up, restart) from other forum but it didn't work.
    Not sure what do you mean by that.
    Are you starting linux and try to connect to a LAN ?
    If it is a program try to paste your C code.
    Yes,im starting up linux via putty terminal. I login successfully using root and type "udhcpc" then "ifconfig". the result don't show the "inet addr" in eth0.
    hi, i managed to make the LAN work by manually configuring the ipaddress of eth0. although it keeps resetted everytime i restart the kit but it's ok for the moment. tnx!
