DE10-Nano mix GPIO I/O directions
- 4 years ago
Case closed! Many thanks!
You can't use the same name for multiple top-level ports, as the error states. You could have something like GPIO_in and GPIO_out, each with the appropriate range, [15:0] and [19:0], respectively. The pinout of the device, configured in the Pin Planner, is where you'd differentiate between the upper 20 pins and the lower 16.
Same thing for your schematic. And there's nothing wrong with a top-level HDL file. But to add the schematics, you have to instantiate them in the HDL code like any other code instantiation:
<component name> #(<parameter mapping if any>) <instance name> (<port map>);
For example for a simple multiplier with a single parameter, give it a unique instance name, pass in the mult_size value to the width_in parameter, and map each signal in top-level HDL code with the port in the instantiated design:
multa #(.width_in(mult_size))
u1 (.in_a(dataa), .in_b(datab), .mult_out(mult_out));
The dot (.) ports are the ports of the lower-level design. The signal names in parentheses are the signals they connect to.
If you're not familiar with the basics of Verilog, this is a good place to start:
https://learning.intel.com/developer/learn/course/external/view/elearning/235/verilog-hdl-basics
