Hi Sstrell,
Thanks as always for weighing in.
A segment of the schematic is attached. This isn’t the final design, it’s a simple test to figure out if I know what I’m doing. As such, it’s been successful at demonstrating I don’t.
HDL is below. It codes what I’m trying to accomplish with a mix of GPIO_1 inputs and outputs and generates the following error: Error (10134): Verilog HDL Module Declaration error at FullRegister.v(26): port "GPIO" is declared more than once
I guess the fundamental question is: is HDL the right approach to declaring the top-level? If it is, how do I get the Fitter to assign my schematic inputs and outputs to the appropriate GPIO_1 pins?
As to my second question: I read that I should instantiate my schematics in the HDL. The schematic is RegU.bdf, ultimately, my design will have many .bdfs. So, the question is do I instantiate all in the HDL, and if so, how?
Thanks again,
Bill McDonald
module FullRegister(
//////////// CLOCK //////////
input FPGA_CLK1_50,
input FPGA_CLK2_50,
input FPGA_CLK3_50,
//////////// KEY //////////
input [1:0] KEY,
//////////// LED //////////
output [7:0] LED,
//////////// SW //////////
input [3:0] SW,
//////////// GPIO_1, GPIO connect to GPIO Default //////////
input [15:0] GPIO,
output [35:16] GPIO
// REG/WIRE declarations
// Structural coding
endmodule
