9 years agoDE10 Nano kit - mini USB OTG without 5V?
I just received my DE10 Nano. Boot it up with the default linux on the sd card works fine. However I am unable to use any usb client devices (mouse, keyboard) plugged in to the OTG port. They only ...
8 years ago --- Quote Start --- How to disable the USB gadget before I cannot use mouse and keyboard control the Desktop? I have tried to disable it in command line but it told me that "QXcbConnection: Could not connect to display"...... --- Quote End --- Try this command when logged in using the serial port as root, then reboot or power-cycle: root@de10-nano:/bin# cd /bin root@de10-nano:/bin# ./systemctl disable de10-nano-gadget-init.service Removed /etc/systemd/system/basic.target.wants/de10-nano-gadget-init.service. root@de10-nano:/bin#
- alid5 years ago
To add, using serial port (connecting the mini-USB port called 'UART to USB' to computer and running a program like Tera Term ) to log in and running the command above solved my problem.
Serial port parameters (couldn't find them in manual): 115200, 8 bit, no parity, 1 stop bit, no flow control.
Also, despite what manual says, there is no password for root.
Hope this helps new users running into this issue.
