9 years agoDE10 Nano kit - mini USB OTG without 5V?
I just received my DE10 Nano. Boot it up with the default linux on the sd card works fine. However I am unable to use any usb client devices (mouse, keyboard) plugged in to the OTG port. They only ...
9 years ago --- Quote Start --- Board: De10 Nano Rev B ....it then goes on to show you how to disable the Gadget via the desktop with a mouse!!! (f****** ****s at Terassic you need a working OTG to use a mouse!!!) --- Quote End --- As another posted mentioned, you need to unplug the mouse/keyboard from the OTG connector when Linux boots. Then after Linux is booted, plug the mouse/keyboard into OTG connector. Then they should work. This was mentioned in the Gettting_Started_Guide.pdf that came with my board. It also mentions that some mice/keyboards might not work with the DE10 due to an incompatibility problem. I have not run into that issue with my equipment -- I am using a Microsoft keyboard and mouse, and a non-powered hub. There should be an icon on the Xfce desktop that allows you to enable/disable the USB gadget.
