De10-Nano GHRD UNSTABLE
The causes may vary, since you have changes in the GHRD which is connected to the HPS, you need to recompile all the design.
E.g recompile in the Platform designer and Quartus, then recompile the device tree, preloader and Uboot.
- hsyn6 years ago
I recompiled all design again but nothing changed. It worked unstable.
I didn't add any constraint for spi and jtag pins.
Which subject should I focuse to? Platform Designer(connections and parameters) , timing constraints , Assignment Editor Parameters (current strength, slew rate, etc.) , own ip cores or verilog codes , noise and reflections , etc.
- hsyn6 years ago
if there is a problem about timing constraints, in this case, it does not work stable with high spi frequencies, does it? But, it didn't work well(not stable) with low spi frequencies also.
- EBERLAZARE_I_Intel6 years ago
It seems that this might be a timing issue after adding those components mentioned.
You need to properly constrain your design.
