VROGE2
6 years agoDE10-Nano 1 Mega Baud Serial Transmission using UART
I have the DE10-Nano Board and I would like to be able to transfer data at 1Mbaud. According to the FT232R data sheet it can transfer data at 1Mbaud using RS232 protocol but when I go into the Platfo...
- 6 years ago
Hello sir,
The UART IP cannot work alone, it should be connected to a processor or a custom logic that take care of the initialization and processing of the IP. I have attached a design example for you to show how to connect UART with Nios II processor. Furthermore, it has a piece of C code to initialize and run a communication stream between two UARTs on the same board.
Thank you,
FawazJ_Altera
6 years agoHello,
May I know which UART IP are you referring to?
Thank you
