LBraz
6 years agoDE10-LITE and RAM: 1-PORT IP - WREN inverted on actual hardware?
I'm starting out with FPGA's on a DE10-LITE and while trying out a RAM: 1-PORT IP on a simple project to put the memory output from a 10 port RAM onto the LEDs, with the 10 switches as input to the R...
AnandRaj_S_Intel
6 years agoHi Luke,
If you are using the switch to control the wren, You may see such an issue because onboard switch may have an active low or active high configuration.
Introduce a "not gate" in the input session of your code(switch/‘wren’).
Anand
