13 years ago
DE1 USB communication
I was wondering if there is any way to have USB communication on the DE1 board? I read a few articles regarding use of the Virtual JTAG which seemed interesting (I am yet to try those).
The Qsys tool shows a USB Controller in its components menu. Can this be used to have a USB Communication? I do not know how to begin :confused:
-Ankur
    Cool. This takes the TCP/ IP route. I am starting the tutorial now. :)
    What do you think about using the Qsys USB controller?
    -Ankur
    --- Quote Start ---
    --- Quote End ---
    I've never used it. You'd need to read its documentation. For example, it might only be available on the newer ARM SoC devices. Older generation devices do not have USB interfaces. A board like the DE1 might have a USB controller (DE2 has an ISP1362), but a Qsys interface to this is "nothing" more than an interface to the device registers. You then need to interface to it using a NIOS II or your own HDL.
    Cheers,
    Dave
    --- Quote Start ---
    --- Quote End ---
    Actually it uses the JTAG interface. The TCP/IP example is layered on top of that so that you do not have to use Tcl if you do not want to.
    Cheers,
    Dave
    Thanx a ton Dave. I atleast have a direction to look into.
    And yes, my bad about that :)
