8 years agoDE1 SoC hangs when programmed
Hi! I have made a small program to make a led flicker and programmed the FPGA with it. Everything went fine. However I have another project which I used to build in a previous version of quartu...
8 years agoIs the project targeting the correct device on your board? Did you adjust the pin assignments in the Pin Planner?
