10 years agoDE1-SOC: Do you know why can't I run Demonstration Batch .bat file as UserGuide says?
Hey there, I think this is a simple question, I'm following the user manual of DE1-SOC by Altera Terasic. Now in the page 59, for making an audio recording and playing project, it is used a dem...
10 years agoThe batch file is the one you mentioned in your question. The command shell is under windows Start->Altera# ## web edition->Nios II EDS# ##->Nios II command shell. Some other common problems to consider: Have you made sure that the path to the Quartus install doesn't have any spaces anywhere in the path? (like "Program Files")? I use C:\Altera for my install. The same thing probably applies to the system CD install as well.
