11 years agoDE1-SoC : change USB3300 PHY host mode to peripheral mode! How To??
Hi, I'm using DE1-SoC board with linux console provided by Terasic. what should i do to change the USB Host mode to USB peripheral mode ? I know that i have to short the ID pin of usb3300 PHY...
11 years ago --- Quote Start --- Hi JalaT, Can you give the details of what you did when you tested it? Did you short the ID pin to 3.3v AND run D+ and D- to the USB connector? When you ran D+ and D-, did you have to disconnect the USB hub as well? I would appreciate any info you could give. Thanks, Rufus --- Quote End --- Hi, sorry for the delay. In fact you have to disconnect the usb hub, and short the ID pin to 3.3V. :)
