11 years agoDE1-SoC : change USB3300 PHY host mode to peripheral mode! How To??
Hi, I'm using DE1-SoC board with linux console provided by Terasic. what should i do to change the USB Host mode to USB peripheral mode ? I know that i have to short the ID pin of usb3300 PHY...
11 years agoHi JalaT,
Can you give the details of what you did when you tested it? Did you short the ID pin to 3.3v AND run D+ and D- to the USB connector? When you ran D+ and D-, did you have to disconnect the USB hub as well? I would appreciate any info you could give. Thanks, Rufus
